Hey mates,
i appreciate all your kind words!!
Maik,
the track is not definitely glued on yet.
I still have some weathering to do which will be more easy when the tracks can be removed.
You will not only see some more pics, you hopefully will see it in person sometime
Michael,
Yes, I used the Eduard Set on the dashboard. It improves it a lot.
As to the sidewalls, ich sanded them down as i didn´t want to spend some more money in the kit. It works pretty good this way.
On ww2mm I heard that the M21 walls aren´t correct either.
I went with sanding and making the rivets and tie-downs with my punch-n-die-set and stretched sprue
Sorry, i´m not sure which ones are the mine racks
Where are they supposed to be (i don´t know much about alliied stuff).
