Old 07-24-2019, 03:41 AM
Glaurung's Avatar
Glaurung Glaurung is offline
StuG III Ausf.B
My next thread will be StuG III Ausf.B. I have chosen Tamiya kit for this one and since I have few leftovers from Dragon's Panzer III family kits I've built before, I use them wherever I can. I have few Aber upgrade sets also to use and aftermarket decals, as I'm going to one of the StuG Abt. 185 vehicles.
I'm not very happy with the Tamiya kit, but there are not many options when building Ausf.B. Bolts are rounded and need to be replaced, weld seams are often missing and need to be reproduced, fit is loose and need a lot of filler. But main problem with this kit is that upper hull, when removing the molded fenders, appears to be 1mm wider than lower hull. I really don't know what to do with that yet. Here is the front driver's plate compared to hull:
But Aber's etched sets seems to be awesome and offers lot of fun. Here's the assembled ammo storage cabinet. And yep, the lid is movable:
Tracks are from MasterClub this time and oh are they awesome. Compared to Friuls, these need very little cleaning and go together with little resin pins.
Til' next time,
Kristjan
Users like Glaurung's post!
Old 07-25-2019, 04:24 PM
Glaurung's Avatar
Somehow, using hot water and brute force, I managed to bend the upper hull narrow enough to fit between metal angles. And after gluing the altered drivers front plate on, it stayed to its new shape. So, the main problem solved, I cannot see any other obstacles to deal with with this model.
I completed both track runs also. The vehicle sits bit high and not so forward-leaning compared to Dragon's Ausf.G, but Ausf.B was 4 tons lighter than Ausf.G so that makes a sense, I guess. I like the Dragon's look more, though.
Kristjan
Old 08-01-2019, 03:09 AM
MZsolt's Avatar
MZsolt MZsolt is offline
Another inspiring start! I'm looking forward to it. How old is this Tamiya kit?
cheers,
Zsolt
Visit my blog:
http://muanyagforgacs.blogspot.com/
Old 08-03-2019, 12:47 PM
Glaurung's Avatar
Thank you!
The kit is not that old actually. It's from 2005 according to Scalemates, but it's not up to Dragon's standards by any means.
Old 01-11-2020, 07:47 AM
Glaurung's Avatar
The StuG was on a pause for a while. I wasn't really happy with the quality of Tamiya, so I decided to wait for a Dragon's new released StuG III Ausf. B.
So, meanwhile I got the new Dragon and can now go on with the subject. I'm going to build these side by side simultaneously. Where there is some detail of Tamiya I'm not happy with, I can now simply clone it from Dragon and replace it. And vice versa of course, but I guess it's unlikely that Tamiya StuG has something superior than Dragon.
Kristjan
Old 01-24-2020, 10:26 PM
Glaurung's Avatar
So by now the stuGs are more or less on the same level by progress. I've added the fenders to the Dragon one. Dragon received some addition to inner bulkhead as well. At the same time I added the sidewalls to Tamiya and it was a fest of filling and sanding.
To the end I add some photos of them together. As you can see, Tamiya's idler wheel is considerably smaller than Dragon's. Don't know, which is right but Dragon seems to be more accurate. Fender pattern is also denser on Tamiya one because of different manufacturers - on Dragon I used Voyager fenders and on Tamiya Aber ones.
I really don't know yet what to do with these two. One option I've considered is to make these as they've been on the same unit - more or less equal in every way. Other option is to give the other another unit and thus different markings and stowage. The third option would be to make these two as different as possible - that would mean another track to Tamiya to use Dragon's 8-hole sprocket and make it feel as different as possible by means of stowage and markings. Suggestions are most welcome
Kristjan
StuG III Ausf.G stassi Photos: In-progress Blogs 5 12-07-2011 11:40 AM
Stug III ausf G trantor breton planetArmor General 5 05-27-2009 09:26 AM
DML Stug III ausf C-D David Diaz Sturmgeschuetz Group Build (closed) 32 07-18-2008 06:22 AM
1.35 StuG III Ausf A Sticky Photos: In-progress Blogs 20 01-28-2007 06:27 AM
The StuG.III Ausf.G is here! amba Your important news and kit reviews. 21 11-25-2006 12:27 PM
