Old 05-28-2016, 09:04 AM
KeroJP4 KeroJP4 is offline
PBR Delta Blues 1/35
Hey guys,
Here's what keeps me busy at the moment, a Brown Water Navy PBR(Tamiya 1/35) that'll be in its element, water.
I used 2 cm thick styrofoam as a base, avilable at DIY shops, in which I cut out the Pibber shape, taking care of how I wnt the boat to properly fit (angle in the water)
Afterwards, I shaped the waves using styrofoam and plaster strips
Ten I used plaster mixed with acrylic paint to shape up the basic form of the river
I used relief putty for the wake foam
I have to change the river color, looks too green and light at the moment. I'll depict the water with clear inclusion resin.
Richard
Old 08-04-2016, 04:34 PM
Time for a lil update of the PBR Vietnam diorama.
Tricky but interesting work ahead : PBR integration into the Mekong resin.
The model was airbrushed with Vallejo primrs (4BO and OD shades) and drybrushed with humbrol light grey.
The antifouling was airbrushed black since it changes from the usual red. Have seen this on some pics ad found it rather cool.
The cockpit aint glued cos I got to get there later for buttons, cushions and levers painting and setting the driver fig.
On the base I worked on the boat print, integrating clear waves, to be detailed later, after the main resin pouring will have set.
Then the PBR was positionned and linked to the base using clear heavy medium gel. Took ten days to get dry !
Before pouring the resin its absolutely necessary to check the base will not be leaking for obvious reasons.
I tainted the resin with a few drops of Humbrol enamel ref 116
Although it doesn't smell, this Cristal Resin from Pebeo/Gedeo contains toluene... Make sure you wont smoke while pouring it and use it outside or open windows and keep out !
Drying in progress tonight :
Too calm a Mekong for sure ! I'll add little waves onces dry.
There I am.
regards,
Richard
Old 08-22-2016, 05:08 PM
Hi gents,
Here are some (way too dark) figures pics.
All paintbrushed Vallejo acrylics.
The grunts completely stunned, were rescued and taken out of hell by the PBR. This is where they met the delta bluesmen !!!!
An M16
1st guy from the Boys Band
Second
Next time nicer pics, I swear
Richard
Old 01-29-2017, 08:41 AM
Long time w/o update... Way too long ago.
So here's where I am !
Richard
Users like KeroJP4's post!
