Old 05-02-2007, 11:57 AM
Caranthir Caranthir is offline
Jagdpanzer VI A/0
Hi all!
It's been a while since i posted here something, so here it go's.
It's dragon's Jagdpanzer VI A/0 with Voyager PE, fruil tracks and tristar suspension. I had a few fit problems with the dragon kit but it worked out allright........almost...
The kit is almost finished, only need to add the schurzen but i can't solder these . I've soldered the whole voyager PE but the dragon schurzen won'work. I think i'll make them from evergreen.
Annyway, this project stands to a halt deu to the warm weather here. My airbrush stand is in the attic and with this weather i'm using more sweat than paint.
The pictures:
Regarsd,
Richard
Old 05-02-2007, 12:26 PM
astralscooter's Avatar
astralscooter astralscooter is offline
Looking good, Richard!
What's the trouble with the schurzen etch? I've had trouble soldering Eduard etch due because of the metal they use. The solder just wouldn't stick, somehow. Can't recollect if I've ever soldered any from Dragon.
Arild
Old 05-02-2007, 01:37 PM
james84's Avatar
james84 james84 is offline
Great indeed!
Voyager makes really good items, just a pity I'm not experienced enough and don't have tools to use them!
Old 05-02-2007, 01:53 PM
Richard
Nice looking Jagdpanzer especially with all those AM bits
Old 05-02-2007, 02:27 PM
very cool looking! I can't wait to see it in paint.
I've tried to solder DML PE and nothing doing... must be the metal formula they use. I've had problems with eduard stuff too.
Old 05-02-2007, 03:56 PM
Regarsd,
Richard
Hello guys.
Have you tried sanding the area that you are going to solder?
If you have sanded it and still can't solder the parts try applying a little soldering paste to the joint before the solder.
Ruben
Old 05-02-2007, 04:49 PM
The Eduard PE has some type of varnish applied, if you hold it over heat for a second it will burn it away and then you'll be able to get the solder to bite.
R
Old 05-02-2007, 07:00 PM
yeah, I've tried that. With the eduard, it works somwhat but I can't get the DML to solder, period. I've tried heat, fiberglass pen, steelwool, etc. too bad
Old 05-02-2007, 07:37 PM
Try sanding it on a piece of flat sandpaper while still in sheet form so the finish is gone, it should solder then, and don't forget the flux.
Laz
Old 05-02-2007, 08:53 PM
yep, I always use good ol' flux
I'll try that sanding tip next time I solder DML PE.
Jagdpanzer IV A/0 Caranthir Axis: World War II 0 03-22-2007 02:16 AM
Jagdpanzer IV ARQUILLE planetArmor General 0 10-15-2006 11:35 AM
Jagdpanzer IV L/70 Stuke Sowle Photos: In-progress Blogs 44 04-24-2005 10:24 AM
DML Jagdpanzer IV L70 James Tainton Photos: In-progress Blogs 3 01-03-2005 09:40 PM
JAGDPANZER IV Sd. Kfz. 162 panzerfist Axis: World War II 0 08-15-2004 09:53 AM
