Go Back   planetArmor > planetArmor Features > Group Builds > Past Group Builds > Sturmgeschuetz Group Build (closed)
Sturmgeschuetz Group Build (closed) StuG III Ausf.G DML Smart Kit - PA Group Build
Closed Thread
Old 04-22-2008, 05:07 PM
DML Stug III ausf C-D
Hello everyone!!
After a long absence from PA its time to end the vacation time and join the “Stug-fest”. This time I will be building DML’s Stug III ausf C/D.
This will be a very basic build, almost straight out of the box but for minor changes. Since Ruben already started one of these and you guys have seen this model plenty of times I will only highlight the differences I will be adding along.
Since Stugs always have large hatches I took this as an opportunity to show some interior details, mainly the radio. So I cut the area where the radio would go to make room for it inside.
Some shots of the superstructure.
Here is how it looks so far. I finished the suspension and glued the loader’s hatch shut.
The main gun also received some attention. Mainly some putty to hide a few defects.
That is all for now. See you guys soon.
top
Old 04-22-2008, 06:20 PM
Looks like a good start!
top
Old 04-23-2008, 06:18 AM
Nice start too...Dave
top
Old 04-23-2008, 07:29 AM
Putty and interior work...David's Back!
top
Old 04-23-2008, 11:06 AM
Thanks Guys!!
top
Old 04-23-2008, 11:38 AM
Dave, nice to ''hear'' from you again. Going good so far!
top
Old 04-26-2008, 06:24 PM
Thanks Siim,
Well, here is a small update on the builds progress.
I attached the fenders and then primed the interior with flat black.
Next I added the PE engine intake covers.
I added the front tow shackles and used some green putty to get rid of the gap between the two pieces.
After some sanding….
Next I started on the weld lines. These were done using fine plastic rod. Liquid cement was used to soften it up and I used the knife to shape it.
I also added the weld lines around the side vision port and on the lifting hooks.
And the weld lines around the gun’s mantle.
I gave the interior a coat of off white.
I then put the hatches in place and covered the radio and sight openings in preparation for painting.
As of now that is where we stand. Thanks for viewing and hope you have a wonderful weekend.
top
Old 04-26-2008, 06:29 PM
Dave- good work so far.
Did you miss the sink marks on the top of the gun mantlet?
top
Old 04-26-2008, 07:09 PM
Fledermaus's Avatar
Fledermaus Fledermaus is offline
DD we are alive again!!!!, just remember this one doesn't have to turn on
and run because of so much detail, so make it AOOTB=Almost Out Of The Box
"Don't be afraid of the model,it's you the one holding the knife"
top
Old 04-26-2008, 08:53 PM
Good Start. Are you going to use radios from the Aber set or steal them from the Smart Kit Stug G?
top
Closed Thread
StuG III Ausf G doubt???? Pedro Sousa Axis: World War II 5 04-21-2008 08:05 AM
The old DML StuG III Ausf.G Andrew Hall Photos: In-progress Blogs 24 02-20-2007 10:28 AM
1.35 StuG III Ausf A Sticky Photos: In-progress Blogs 20 01-28-2007 06:27 AM
The StuG.III Ausf.G is here! amba Your important news and kit reviews. 21 11-25-2006 12:27 PM
StuG III Ausf. A Markus Photos: In-progress Blogs 10 08-16-2005 04:06 AM
