Old 09-08-2010, 10:03 AM
Panzerjaeger's Avatar
Panzerjaeger Panzerjaeger is offline
My Car has Zimmerit
Nashorn - Dragon 1:35
Thread thumbnail:
Andy
"The World has taken a turn for the surreal. . ."
vBench | Picasa Web Albums | AMPS Chicagoland
Old 09-08-2010, 10:10 AM
My Car has Zimmerit
The PE Fret has front fender hinges to replace the molded-in standard versions.
ID:	3467Click image for larger version
I made the hinge pins from 34 gauge annealed steel wire (left). Getting started on the gun (right).
ID:	3469Click image for larger version
First gun build phase primed and painted and more parts going on. I'm going to do this in stages and paint as I go. This is a fairly complex assembly.
Gun on hull. I made a slot-and-bar modification so it wouldn't fall off the model. The way Dragon designed the kit, it would have to be otherwise glued in place, especially with the weight of the metal barrel. I figure with this level of detail and effor, the gun should pivot!!
ID:	3472Click image for larger version
Thanks for checking in!
Andy
Old 09-09-2010, 05:16 PM
Pvt Mutt's Avatar
Pvt Mutt Pvt Mutt is offline
Great start Andy. I've got one of these as well and all i've done so far is look at it. I also got the new AFV Club Nashorn but i've at least got the running gear installed on it.
Just too many I want to build.
Tony the Mutt
Old 09-10-2010, 08:48 AM
Nice start... keep it up.
Old 09-10-2010, 09:57 AM
My Car has Zimmerit
Thanks, guys. I did some more work on the gun last night and will have some pictures soon.
Andy
Old 09-11-2010, 10:58 AM
WillysJeep's Avatar
WillysJeep WillysJeep is offline
Looking good Andy.
Tim
Old 09-13-2010, 09:31 AM
My Car has Zimmerit
Thanks!
I made some more progress towards the end of last week and over the weekend.
I finished adding the detail to the gun (these photos don't show the sight).
ID:	3503Click image for larger version
With the base of dunkelgelb. I had a heck of a time with the sight. It was supposed to attach to the left pivot shaft of the gun (trunion?), but the pin was too short and small to accomplish a mechanically-sound glue joint. I had to drill out the pin and insert a steel shirtpin just to get the thing attached.
ID:	3506Click image for larger version
The PE side vents were actually less difficult. I had trouble keeping the vanes straight and there's some glue cleanup to do, but I plan to make them look decent by the time I'm done. The filler is from a little over-zealous filing.
ID:	3505Click image for larger version
By the way, on the subject of fillers, I've started using automotive spot putty. I find that it is much smoother and gives a little more work time than Squadron putty. That lets me get it on and smooth in a thinner layer and get to sanding it smooth sooner. Part of the problem is probably that my Squadron putty is getting a little old, but then again, I don't recall it ever working as nicely as this spot putty.
It's a little rough around the edges and not as clean a build as I would like, but it is coming along.
As the first Dragon kit I've carried through this far and being a long time Tamiya junkie, I can definitely say that Dragon kits are not as easy to build, particular from the standpoint of complexity (a good thing), cleanup (not so good) and fit (not as good as Tamiya). They are definitely not for beginners! In Dragon's favor, however, the inclusion of so much PE, other detail-enhancing aspects and their incredible variety of interesting subjects makes them a must-have for me in my kit stash and model collection.
As always, comments and questions are welcome!
Thanks for checking in.
Andy
Old 09-13-2010, 09:48 AM
Pvt Mutt's Avatar
Lookin Good Andy
Tony the Mutt
Old 09-14-2010, 07:26 AM
canjuaan's Avatar
canjuaan canjuaan is offline
Yep, good work so far. One of the best looking SPGs of all time
Johannes
Misses modelling.
Old 09-30-2010, 03:50 PM
My Car has Zimmerit
Thanks, guys!
I got the tracks built-up and some of the fighting compartment built.
ID:	3527Click image for larger version
ID:	3530Click image for larger version
The tracks are in two sections so they could be removed for painting. The top section curves around the idler and sprocket and the bottom section comprises the flat portion and the curves under the sprockets and idlers. You can see where I have Tamiya tape to hold them in place.
I masked the engine grilles so they could be primed separately.
ID:	3532Click image for larger version
Over the last few sessions, I've been working on the minute details of the upper hull.
Andy
Dragon Sd.Kfz. 164 Nashorn - Büffel oder Haifisch holmerz Photos: In-progress Blogs 12 05-06-2014 04:50 PM
PE for Nashorn holmerz Reference 0 01-06-2009 05:10 AM
Nashorn Evan August Photos: In-progress Blogs 14 11-25-2006 11:47 PM
DML's Sd. Kfz.164 Nashorn Flak Photos: In-progress Blogs 16 05-25-2006 03:19 AM
DML 1/72 Nashorn Tuna Photos: In-progress Blogs 0 10-23-2005 05:49 PM
