Go Back   planetArmor > planetArmor Features > Photos: Finished Projects
Photos: Finished Projects Post photos of a build that you want to showcase or get constructive critique.
Old 03-10-2012, 03:08 AM
Single Hand Welder Rig on a dually pick-up, 1/25 scale.
1/25th scale Dually Pick-up Conversion to Welding Rig.
Converted model built by, Captfrontera.
All photos and text by, Captfrontera.
A scratch-built/conversion of a welder as I used to operate it in the oil field. The cab is a snap together and from the rear of the cab back, (except the axles and wheels) all are scratch-built.
-The bed is diamond plate surface that angles to a wider width to accommodate the duel wheel width.
-The rear bumper has a hitch plate.
-The "head-ache" rack has mesh installed.
-The welding machine is a Miller Big 40, it will include lift ring, exhaust pipe, radiator cap on the mesh end, and so forth.
-Torch, hoses, welding leads have been added.
-At the end of the bed, the angle iron serves as a ready jig to line-up and weld two pieces of pipe together at the ends.
-The rectangles are built in tools boxes which will have pull latches just like the original.
-Painted the wire to simulate the ox and acetylene hoses.
-Built the ox and acetylene gauges w/lenses.
-Custom made decals added to the welding machine.
-Inset rear working lights and tail light cut outs w/grill added.
-The floor mats were made from tape.
-The dash numerals and indicators were hand painted. I also added a clear piece to simulate the cover.
-The stick shift was scratch-built.
-The dash board area was detailed as were the arm rest/door handle areas
-Inspection stickers (windshield).
Old 03-11-2012, 06:39 PM
Bob Bethea Bob Bethea is offline
Way past cool. Wencho. Is it 1/25 or 1/32? I love it
Old 03-11-2012, 11:05 PM
Thanks and will pass on the compliment to Captfrontera.
The scale of the build is 1/25th.
Thanks for asking.
Photo Review of Meng's 35 scale Pick-up Trucks sharkmouth Photos: In-progress Blogs 3 01-21-2012 04:55 AM
single action airbrush KuKŁiNsKi Painting & Weathering 31 03-18-2011 07:25 AM
251/c in 72 scale mic bradshaw Photos: In-progress Blogs 1 01-25-2006 10:53 PM
Put your hand up Flak planetArmor General 5 07-28-2005 05:00 AM
1/48 scale T-34-76 panzerfist Allied: World War II 0 06-05-2005 12:35 PM
Copyright ©2000 - 2018, Jelsoft Enterprises Ltd.
