Old 12-29-2006, 08:21 PM
Tips & Tricks
Hello everyone!
I finally had the time to post the Tips and Tricks thread. As you guys can tell the thing I enjoy the most is making dioramas. Building and painting vehicles is lots of fun but what I like the most is making the scenery for military dioramas.
The purpose for this thread is to share some techniques and ideas I have learned and accumulated during the years. However, that is not its only purpose. If you have similar ideas or techniques I would like to hear from you. And also if you are trying to get a specific effect on a diorama, and can’t seem to get it right we can discuss it here and maybe we can find a way to do it. I will be posting new ideas as I get the chance.
1. Making rubber molds for plaster blocks
Using silicone rubber to make molds in order to create unlimited number of modeling pieces is not a new technique. It was created and refined by train modelers and wargammers in order to create their sceneries.
I have been using this technique for a few years now and I have to say I love it! It is perfect for building structures for 1/35 military dioramas. Even if it looks a little intimidating, its quite simple and easy to master.
The first thing to do is to make your masters. These are the pieces you want to copy. I usually make my masters in plaster also, this because plaster is easy to sculpt and sand into shape. Geometrical and straight shapes are the easiest to cast. The important thing is for the part to have a flat side. This will be the side facing down when you pour the rubber.
If you are making building blocks for structures your measurements must be precise. I can’t stress this enough. Otherwise your pieces won’t be interchangeable. The best thing is to make a good number of masters, this will make duplicating faster.
I like to make my molds on top of a piece of glass. The benefit of this is that the glass is not going to bend and therefore warping of the mold will be avoided. Once the masters are done I secure them to the glass using School Rubber Cement. This is done to prevent the parts from floating once the rubber is pour. Floating parts will ruin your mold!
Once they are secured I build the case for the mold. For this I use LEGOS. (Don’t worry no kids were harm during this exercise ). A coat of rubber cement was applied to bond the legos to the glass. It is best for the legos to be new, as they will fit tight and will prevent leaks.. If the legos are old place some tape around the outer edge of the case once you build it. (Or be patient, the kids will get tired of those Christmas presents before long ) Make sure to leave about half (1/2) inch from the pieces to the wall.
There are many types of rubber available. Some places you can get it from is at www.MicroMark.com, or www.Smooth-on.com The best rubber to use for your first try is one that comes in equal parts and mixes 50% and 50%. The one I use mixes one part of catalytic (the red liquid that makes it dry) for every ten parts of rubber. And you have to weigh it and stuff... , so the easiest way to go is the 50/50.
After the rubber is mixed it is poured into the mold. It takes quite a while to dry. The best thing is to leave it overnight.
After the rubber is dry you can remove the lego case. The rubber cement comes away really easy.
You can then flex the mold to remove the masters.
Your mold is complete!
Now it is time to cast some more pieces. A very important step is to spray the mold with a mixture of water with a few drops of dishwasher soap in it. This is known as “wet water”. What happens is that water has a very high surface tension; this causes the water to kind of stay out of the details of the mold. Since plaster is diluted in water this will result in plaster not entering small details creating ugly bubbles in your pieces. I use dishwasher soap because it is designed not to foam, and therefore won’t create new bubble in your pieces.
Without wet water
We then fill the mold with plaster.
Now you can make as many pieces as you need.
All you have to do now is let the plaster dry overnight and build away!!
I hope this brief description of this technique was helpful. If you are like me and you like building dioramas, this is a very useful tool.
Until next time
Model on!
Old 12-29-2006, 09:01 PM
Great tutorial! Let's hope other people will contribute.
Old 12-29-2006, 11:13 PM
Thanks Fletcher!
It would be real fun to see and compile different techniques from other modelers.
Old 12-29-2006, 11:24 PM
Nice tutorial.
Old 12-30-2006, 05:16 AM
Jan Peters's Avatar
Jan Peters Jan Peters is offline
Thanks for sharing Dave!
Jan
MAGNA CUM NADA
Old 12-30-2006, 01:01 PM
Very nice of you to post this.
About adding to this thread, does it have to be diorama related or can it be something else?
Siim
Old 12-30-2006, 01:28 PM
Siim
Absolutely Siim!
You can add any ideas or techniques that have worked for you in the past. I will be adding some related to model building as well, not just dioramas. (I just like dioaramas a lot ) The idea behind this thread is to make a collection of techniques and ideas so we could use it as a kind of reference.
Old 01-03-2007, 05:10 PM
Primus's Avatar
Primus Primus is offline
Tips and tricks are great! I learned a lot from this sbs. I will try this technic as soon as possible
Old 01-05-2007, 09:12 PM
Great tutorial
Old 01-05-2007, 11:27 PM
Thanks Lawrence!
Making of headlight for my Panzer Werfer 42 watanabe Photos: In-progress Blogs 21 02-18-2010 07:24 AM
Making of MG mount for my Panzer Werfer 42 watanabe Photos: In-progress Blogs 11 11-16-2006 07:47 PM
Making trees Finnmodeler Photos: In-progress Blogs 13 10-20-2006 07:43 AM
Fine Molds Millenium Falcon Striker planetArmor General 5 09-23-2006 11:37 AM
Making tarps for AFVs olin Scratchbuilding 6 09-09-2004 11:13 PM
