Old 01-15-2011, 09:21 PM
help
somebody has to know how to roll pe so how do you do it? ive tried and its got me stumped
Old 01-15-2011, 09:32 PM
gordy gordy is offline
Founder
How tight of a roll ? You can experiment with a section of the photo-etch frame on various things like nails, xacto handles, etc ..
Old 01-15-2011, 10:43 PM
i figured it out, measurement of piece to be rolled divided by 3.1416 equals the dia of the rod to be used to roll the material. it works. now why dont the pe makers just tell you the dia of the pcs to be rolled. also if i am not wrong most if not all the pe kits out there will probably be metric in size. part im trying to roll is the spare antenna holders on the hertzer, dia is .039 roughtly 1mm thanks for the quick reply.
Old 01-16-2011, 01:59 AM
It's great that you figured it out.
Old 01-16-2011, 09:15 AM
but it cost brain cells, and a splitting headache afterwards
Old 01-16-2011, 10:07 AM
hondatech2k2 hondatech2k2 is offline
I have a mission models multi tool (large). I heat up the PE and bend it around that. If I need anything bigger I usually can find it out in my garage.
Old 01-16-2011, 10:22 AM
ive been looking at those at the hobby shop. i think they are a bit pricy, what i dug out of the toolbox in the garage is a set of drill indexes, only thing is they are sae so its close size.
Old 01-17-2011, 04:10 PM
next q
anybody been to see the german armor up close, if you have whats the dia of the conduit for the notek driving lights, if you did not measure a guesstimation should suffice. thanks
