Old 10-22-2008, 06:59 AM
Fledermaus's Avatar
Fledermaus Fledermaus is offline
sdkfz 9 Famo w/trailer dio
Hi to all, its being a wile since my last update but finally I have finished the diorama for the stug IV, I don’t have photos of the famo+ trailer build as I started it about two years ago. I took photos of the base process and the stug was already posted, so here are the photos…….
I started by making the parts using a rubber mold an plaster, then you put all the pieces together to form the street.
And this is how it looks when finished….
Then using another mold I created the side walk
Next using styrene I constructed the fence pillars to make a mold from it.
And for the pillar top I used a piece of the side walk, sanded it smooth and cut it in two squares one bigger than the other and glued it together
Here are all the parts assembled, this is how its going to look completed….
The mold is made and the parts are ready to make the fence, I’m using a verlinden gate
And a metal fence parts I found in Kmart from a Christmas set
"Don't be afraid of the model,it's you the one holding the knife"
Old 10-22-2008, 07:01 AM
Fledermaus's Avatar
This is the overall look of the fence with a damaged corner…….
Next I started the painting step by giving it a wash with black and dry brushed with shades of grey and followed with some pastel powders, also painted the fence and added some static grass and silflor to the back of the fence and two street lamps on the corners
At the end I changed the bent fence and put it on the floor as if it was blown from the force of the explosion. Well that’s all for the base, next pictures are the completed scene
With the famo and the stug together…….
Old 10-22-2008, 08:37 AM
Looks Great SBS progress
Old 10-22-2008, 05:28 PM
Fledermaus's Avatar
thanks a lot flak
Old 10-22-2008, 05:30 PM
Fledermaus's Avatar
And finally here are the photos of the finished diorama…………
Old 10-22-2008, 05:31 PM
Fledermaus's Avatar
And now I can say it is finished….thanks for looking!!
Old 10-22-2008, 06:09 PM
At last!!!
It only took you what? Two years? hehehe I think it was well worth the time and effort.
Old 10-23-2008, 12:43 AM
kostas.13.'s Avatar
kostas.13. kostas.13. is offline
Good work in these street and armor.
But too much...yellow colour.......
Old 10-23-2008, 01:24 AM
Wow...BIG project and GREAT diorama and GREAT work
BTW...how long is the diorama
Old 10-23-2008, 10:07 AM
Fledermaus's Avatar
Originally Posted by Sturmmann View Post
At last!!!
thanks DD , I hope to have more time to model and I will try to work faster
the model stack looks bigger and bigger........
thanks Kostas!! that was the first thing I noticed when I took the photos
the models look like Bright yellow and it is not like that, I'm starting to work with photo shop and did something wrong with the pictures and ended like that
I think it was the auto level adjustment plus the fluorescent light I was using when I took the photos, if you can compare with this early photos of the famo there you
can see the real color of the models...here is the link
http://www.planetarmor.com/forums/sh...t=3767&page=11
thanks again flak, the base is 31" x 11" ,the famo with trailer are very big
so the base no matter how you try is going to be big....
MAZ-537 trailer done jurjen zuijdendorp Modern 7 08-03-2008 04:46 AM
Red Baron trailer James Tainton planetArmor General 1 07-26-2008 08:29 PM
What color was the undercarriage of the FAMO SdKfz 9? Stillhawk Axis: World War II 2 12-28-2007 06:33 PM
FAMO TRAILER? darrengreenwood Axis: World War II 1 04-10-2006 12:56 AM
