Old 07-05-2007, 04:05 PM
Stug question - mixing DML for Stuh
Hello!
I have the DML Imperial Series Stug III G 10,5 cm kit. I want to make a Stuh 42 with the early upper hull.
As I understand, I need to get the Stug III F kit for that and mix parts with the imperial kit to get the best representation. So do you think it would be reasonable or would the F kit need too much updating to get it looking good?
Old 07-05-2007, 06:12 PM
I'm thinking you want to build one of the early StuHs based on the Stug Ausf F? After checking Achtung Panzer, I think that there is a little more work to it than a simple kitbash. The roof ventilator, and the raised portion of the roof that it sits on is a different size and shape on the StuH. You'll most likely need to rework the roof and do some scratch building.
Old 07-05-2007, 08:05 PM
StuH based on the F were kinda rare. More were based on the F/8 and G. The best kit to start with I would think would be the new tool StuG G for the lower chassis, you will need to modify it of course, but at least you would have a good starting point. Then use the F upper hull and superstructure. Like Evan said you will need to modify the ventilator. For a quick go, just use the F kit and an aftermarket 105mm gun. You will still need to change the ventilator, but that would be all.
Old 07-06-2007, 11:37 AM
Thanks Evan and John for the clarification.
Got a New Question for you Pvt Mutt Axis: World War II 9 11-02-2006 02:23 AM
A question ... or two lepman Axis: World War II 2 11-10-2005 03:35 AM
FS QUESTION POPPYBILL planetArmor General 1 10-09-2005 02:23 PM
Well now, I do have a question.. modelman62 planetArmor General 2 08-20-2005 03:56 AM
Question or two ? Dragan Axis: World War II 11 04-23-2004 06:04 PM
