Old 09-08-2015, 06:01 PM
Pvt Mutt's Avatar
Pvt Mutt Pvt Mutt is offline
DML Marder II
I was clearing off the work bench today and found this one, where did that come from????
It's not so bad to get old after all huh
Tony lee
Shoot Low Boys
They're Ridin Ponies
Old 09-11-2015, 04:46 PM
Pvt Mutt's Avatar
Finished cleaning up the hobby room yesterday so today I blew it apart
to check the interior for any missing parts I may have overlooked.
Everything was there so I glued the upper and lower hulls together.
Next thing was to install the item that were left off until the hulls were joined.
While the glue cured the next step was to clean up the tools and apply the color base coat which i'll let dry overnight.
The Muffler/Silencer was cleaned and assembled. NOTE: Don't install it when the instructions call for you to but install after you've got the hull glued together.
See Ya Later
Tony lee
Shoot Low Boys
Old 09-12-2015, 03:41 PM
Pvt Mutt's Avatar
Update:
Parts that were left off installed, tools and muffler painted.
Oooops, for the ax
Bench closed till Monday
Tony lee
Shoot Low Boys
Old 09-12-2015, 05:50 PM
nice little marder )
Old 09-12-2015, 06:57 PM
Pvt Mutt's Avatar
Thanks Andrey
Tony lee
Shoot Low Boys
Old 09-14-2015, 11:47 AM
Pvt Mutt's Avatar
Shop is open
Dusted her off with a large makeup brush.
Applied light coat of satin clear, drying now.
Only a thin coat of filter will be applied because I don't want an over powering blue cast.
Back later with the results
Tony lee
Shoot Low Boys
Old 09-14-2015, 02:53 PM
Pvt Mutt's Avatar
Filter Update
Only one coat of filter and it's blue enough to suit me. This color is strong so a little bit goes a long way. Applied with a damp NOT wet flat brush. Shake the bottle before you load your brush each time for a even tone.
Tony lee
Shoot Low Boys
Old 09-15-2015, 03:01 PM
Pvt Mutt's Avatar
Update
Future coat,decals and tools. Unknown Unit Eastern Front
Pin and overall washes are next
Thanks
Tony lee
Shoot Low Boys
Old 09-15-2015, 08:30 PM
Well, good recovery. I have so many half and three quarter (or more) finished projects it's saddening. Good job.
Old 09-16-2015, 09:40 AM
Pvt Mutt's Avatar
I hear that Roy. I get started on one and something else grabs me that i've just got to build. Before you know it they are stacked up in que.
Good thing companies have slowed down with new releases of SPGs which gives me time to catch up.
Thanks Roy
Tony lee
Shoot Low Boys
Marder 1 specmod Photos: In-progress Blogs 7 02-26-2009 12:21 PM
Marder 3 specmod Photos: In-progress Blogs 4 09-11-2008 12:09 PM
DML Marder II sam_dwyer Photos: In-progress Blogs 92 11-16-2006 05:21 PM
Marder III Radek Photos: In-progress Blogs 11 02-10-2006 06:24 AM
Marder III M Finnmodeler Photos: In-progress Blogs 2 03-17-2005 08:11 AM
