Old 09-24-2012, 04:02 PM
MM1 TB MM1 TB is offline
Wire cutting
I am making metal track for my Elefant and was wondering if anyone knows where I can get a wire cutter that I can cut wire to same lenghts, like a sheetmetal shear????
Old 10-22-2012, 09:01 AM
baskette's Avatar
baskette baskette is offline
Cut a section of plastic tube to the length you want your wire track pins. Blank off one end with sheet styrene. Insert wire until it hits bottom and the cut it off flush with the top of the plastic tube using standard wire cutters and repeat. After several repeats, dump the equal length pins into a seperate container and then have at it again.
Wesley and Jack, heirs to my fortune... Boy won't they be disappointed.
Old 10-22-2012, 01:41 PM
Smile Thanks
Thank you so very much. I haven't worked on the track because it was a pain. Now I have some incentive to get it done. It worked perfect.
wire cutter pic James Tainton Reference 5 11-11-2007 09:51 AM
Accessories: Concrete Post, Barriers, dragon teeth;Tow cable; Barbed wire-Scale 1/35 Ricardo Your important news and kit reviews. 2 10-16-2006 03:10 PM
Cutting Edge web page? DOJO planetArmor General 2 08-10-2005 04:18 PM
Cutting brass sheet James Tainton planetArmor General 3 02-01-2005 03:16 PM
