Old 01-03-2007, 02:19 PM
Making Nuts & Bolts
Hello Everyone!
Thanks to Gordy for moving the threads to the Idea Factory section. Iím sure they will be more useful for everyone like this.
Part 2: Making Nuts & Bolts
In this thread I will discuss some methods of making your own nuts & bolts. This simple methods will save you time and frustration when scratch building or when adding those missing details to your kit.
All you really need is some round and hexagonal plastic rods of different sizes. These are available at hobby stores or online.
Simple Bolt Head
To make a simple bolt head just cut the hexagonal rod (Iím using a large size to illustrate it better). You can vary the thickness of the bolt by cutting thinner slices. This takes practice so donít get too frustrated.
Then glue it in place.
Nut & Bolt
To make the nut & bolt end just cut a hexagonal piece like before then cut a round rod the desired length.
After that, glue the hexagonal part first (the nut) then the round piece (the bolt).
Washer & Bolt
To make a washer & bolt combination simply do the same but now in reverse. First cut a thin disc out of round rod and glue it. This will be your washer so the thinner the better.
Then cut a hexagonal piece of slightly smaller diameter, and glue it on top of the washer.
If they donít look completely flat as sometimes is hard to cut at right angles wait until the glue dries and then you can file it or sand it flat.
Simple Flat Head Rivets
A simple way of making simple flat head rivets is using a leather puncher. This is a tool made for making holes in leather belts and stuff. You can buy it at craft stores and it works great on plastic.
First punch small discs using the smallest diameter available. The smallest I have seen is 2mm; this is rather big for most 1/35 vehicles, but it works good for structures or if you ever need a round disc this is an easy way to cut one.
Then glue the discs to represent a line of flat rivets.
That is all for this week. I hope these methods are helpful.
Model on!
Old 01-03-2007, 03:18 PM
T140's Avatar
T140 T140 is offline
Nice one David, stuff like this is great for me. Keep it coming.
There's reference in a book I have to a punch and die set for domed rivet heads, and I wondered if you have used or would recomend one, if they can be obtained of course.
Old 01-03-2007, 05:05 PM
Balki's Avatar
Balki Balki is offline
Thanks Dave. Simple and beautifull. You are right, this takes practice. So far none of the small pieces I cut came out straight. I need more practice, a lot more practice....
God and the soldier, we adore, in time of danger, not before.
The danger gone and all is righted, God is forgot and the soldier slighted
Old 01-03-2007, 05:48 PM
To make domed head rivets, you can hold the end of the rod to a candle to mushroom out the end. Then just slice it off and do it again.
Old 01-03-2007, 09:05 PM
Thanks Ian. Lest hope more people get motivated to contribute to the thread. I will be posting more as soon as I get the chance.
I actually donít own a punch set, but a friend of mine does. The greatest advantage I see is precision. If you need to make lots and lots of bolts and rivets and they will be close to each other then you want that kind of precision. The only drawback is that some of these sets are insanely expensive. I do have seen some that sell for around $25.00 however, but I am not sure as to how precise they would be. Anyways, making your own punch a die tool is not hard to do, and is fairly inexpensive.
Or, like Fletcher said using heat to make a dome is a simple and easy method you can try. (Thanks for that one Fletch! )
Yeah, it is hard at first, but donít get discouraged. I get bolts that are crocked as a barrel of snakes all the time! Remember you can always file or sand the pieces once they are glued. There are some tools like ďthe chopperĒ that work great for this. If you can get one of those it is fairly easy to cut them straight.
Old 01-04-2007, 10:06 AM
Totenhosen's Avatar
Totenhosen Totenhosen is offline
die Geisteskranker
Send a message via AIM to Totenhosen
Another method to make domed rivets is reverse-chuck a tiny drill bit or brass rod and punch them through a sheet of tin using a thick peice of rubber (like the sole of a shoe) as a backer. Works like a charm. Only downside is you have to dig the rivets out of the rubber with the tip of a scalpel blade. You could probably substitute a sheet of thin styrene for the tin and that should work just as well.
"Nice f**kin model!"
- Beetlejuice
Old 01-04-2007, 11:34 PM
Ken I have seen that method used, and it works. It is a good stop-gap. But on the long run I know one gets tired of digging bolts out of rubber.
But actually if you have access to a machine shop, or if you have a good drill press you can build your own punch & die tool really easy. If anybody is interested I am willing to show them how.
Old 01-05-2007, 02:12 AM
T140's Avatar
Please do Dave. My number 2 son works in an engineering shop, so I could ask him to have a go for me.
Old 01-05-2007, 11:39 PM
Thatís great Ian!
I am going to make some drawings and I will get them to you as soon as I can. Maybe it may be helpful to make a thread on this since it is better to illustrate that way.
Old 01-06-2007, 06:27 AM
Look at this link, the forum there is in estonian so you probably will not understand the text but the pictures tell a lot too. It is another way of making rivets, nuts and bolts.
http://www.militaar.net/viewtopic.php?t=5261
Siim
Making of headlight for my Panzer Werfer 42 watanabe Photos: In-progress Blogs 21 02-18-2010 07:24 AM
I'm making chassis frame of Sdkfz 4/1 watanabe Photos: In-progress Blogs 310 04-05-2008 06:26 AM
Making of MG mount for my Panzer Werfer 42 watanabe Photos: In-progress Blogs 11 11-16-2006 07:47 PM
Making trees Finnmodeler Photos: In-progress Blogs 13 10-20-2006 07:43 AM
Making tarps for AFVs olin Scratchbuilding 6 09-09-2004 11:13 PM
