Old 01-15-2014, 08:58 AM
simon simon is offline
swedish S tank
having now posted this in the right forum I was wondering if any of you could help. I am thinking of building a Trumpeter S tank - one of which I built when they first came out - and seam to rember that the runing gear and tracks where a bit of a let down. Did the S tank use Centurion wheels and track links? If so then that leaves the posibilites of using aftermarket items to improve what I thought was the kits main downfall.
Old 05-21-2014, 12:21 PM
sherman-vc's Avatar
sherman-vc sherman-vc is offline
Hi Simon, not sure which S tank kit you have but Trumpeter did release a set of indy tracks for both the B and C I think, you can also use leopard I tracks for the C, Hong Kong Creattions used to make a set but there is also a set from Ochi and Meng on the market now.
Rod
Rod
"The squeaky wheel doesn't always get the grease.... often it gets replaced."
swedish s tank. simon Armor Art - Non-Model 0 01-14-2014 01:05 PM
