Old 04-04-2009, 03:07 PM
Dazzer's Avatar
Dazzer Dazzer is offline
Japanese Type 3 "Honi III"
Hi again all,
Right, im determined to attempt a true SBS, utilising the FineMolds Type 3 "Honi III"
Here is the box art...
I'll be building OOB, apart from Barrel and Friuls. Here is the barrel, awaiting Friuls..
For painting I'll use the recommended Mr. Color paint set for the main colours...
and assorted other paints
Old 04-04-2009, 03:10 PM
Dazzer's Avatar
Reference material is low on the ground. Apart from a few internet based grainy B/W photo's, and internet based hand drawn picture, I only have the following source materials.....
If anyone can recommend further info, ESPECIALY regarding the interior of the 'turret' it would be appreciated
Old 04-04-2009, 03:13 PM
Dazzer's Avatar
OK, moving on, the instructions....
Sprue details...
and assembley....
(More to come)
Old 04-04-2009, 03:15 PM
Dazzer's Avatar
Instructions continue....
and paint scheme......
Old 04-04-2009, 03:19 PM
Dazzer's Avatar
The Sprue's....
Sprue 'A' (Two of these)....
Sprue 'B' (again, two of these)...
Sprue C (Just one) ....
More too follow...........
Old 04-04-2009, 03:23 PM
Dazzer's Avatar
Sprue 'D' (again, just one)....
The 'Turret'....
The 'Perspex' (i'm concerned that the vision blocks are 'blanked out' in the instructions . Hopefully I'll find a use for them)
The P.E......
and the Transfers...
Old 04-04-2009, 03:24 PM
Dazzer's Avatar
The Hull 'bucket'....
and the track (as mentioned earlier, I'll be using Friuls)...
Old 04-04-2009, 03:34 PM
Dazzer's Avatar
OK, and to work
Started on the really exciting part, the suspension
Final Drives - OK, some flash, but minimal, requiring little clean up. Warning though, there is a lot of lateral movement between the two halves of the Final drive pieces when you come to glue. Be carefull or the sprocket 'teeth' will not line up!
Wheels, again, not to bad, though clean up required (not exactly a 'ridge' line on wheel rubber, as you can see from image below there is a difference in depth, creating a 'step' that needs sanding)...
The 'Wheel Arms' (what would you call them?) have mould lines that need eradicating (in the pic below I have done that on the left hand side, leaving what it is originally like on the right)....
Old 04-04-2009, 03:40 PM
Dazzer's Avatar
The Wheel 'Arms' are fine from the front....
From the rear they need attention, but, as this cannot be seen when assembled, i wouldn't bother....
My pet hate next, shock absorbers. Why do the sprue attachment points have to co-incide with springs, involving Micro-surgery sanding?????....
Note, one of them was broken prior to removing from the box
Anyway, i will rebuild these later
So, where am I???? Wheels all done and dusted, Final Drives done, Road Wheels done, Idler's done....
More updates to follow.
Thanks for looking
Old 04-04-2009, 05:20 PM
Moon Puppy's Avatar
Moon Puppy Moon Puppy is offline
Great start. Hardly ever see anyone do Japanese Armor.
Befehls Panther Ausf G "151" Kampfgruppe Peiper Ardennes 1944 lquah Photos: In-progress Blogs 85 01-17-2012 12:02 AM
New walkaround:soviet rocket launcher BM-13 "Katyusha" on the shassis a STZ-5-NATI tr Pavel Blinov Reference 2 03-10-2009 12:16 AM
Type 89 "Ot-Su", finished (yes it's true) Joaquin G. Gazquez Photos: In-progress Blogs 17 10-19-2007 05:41 AM
Show & Contest ! "Showing Our Support " April 28, 2007 ! dukwhunter Armor Shows and Events 0 02-08-2007 07:57 PM
Japanese Type 95, Type 97 & US 75mm Pack How pics @ Toadman's toadman Your important news and kit reviews. 0 02-06-2007 02:57 AM
