Old 08-31-2009, 04:22 AM
mykman mykman is offline
mykman
Sd.Kfz. 234/3 Schwerer Panzerspaehwagen (7.5 cm)
Hi all !
I started this project , 2 mondh ago. It begun a fast OOB bulid but it turned out a full upggade project.
The full upgrade was inspired by Flak`s awesome 234/3 unit
The kit is the dragon 234/3 , and a griffon clamps set. Meanwhile i designed a full photo etched set for this vehicle , and i have to say it was a real pain in the ass for the end of the drawing. I would not thout it was a hard job to do. But it is nearly finished , and send to the craftsman .
So here i stand now. I started with the running gears , i made the brake cables from 0.2mm brass rod. The rear wheel arm is a late version with different wheel hub and pattern.
Here is the late version arm , with some Brown stuff.
Comment are wellcome !
And sorry for my english
Old 08-31-2009, 04:55 AM
canjuaan's Avatar
canjuaan canjuaan is offline
the first pics look promising. You wrote you designed a full PE set for this kit? Are there any preview pics available? Will it be available under a PE company like ABER or Voyager?
Johannes
Misses modelling.
Old 08-31-2009, 05:43 AM
mykman
Yes i made it one. but only for myself , not for a company
The seet was made for several projects , not just the 234. It would be compicated to relase it in the market , and i haven`t a free time for it.
I haven`t much hobby time so i will be happy if I can finish the 234 in a few months.
Old 08-31-2009, 10:35 AM
Nice start!
Old 09-02-2009, 03:29 AM
Nice start...
Old 09-02-2009, 08:00 AM
mykman
Thanks for the comments
I try to update soon.
Do anyone know what is this item exactly ?
J H18,H7,H22
It is a munition holder for the 7.5 ammo , or something ?
The 234/4 has similar but i`m not shure what it is.
Old 09-02-2009, 12:05 PM
Don's Avatar
Don Don is offline
Send a message via MSN to Don
Szia Mykman!
I saw this somwhere...
Keep going, nice build!
Don
Old 09-04-2009, 02:05 AM
Halihó!
Sorry, I can't help you with that, maybe try to find out by reading trough the instructions...
Arthur
Old 09-22-2009, 02:54 AM
mykman
Update
I started to build the crew compartment. The gear shift levers are replaced with 0.4 mm rod. I don`t planning to open the drivers hatch , so the drivers area is not will be seen in the end , so i think theese updates are enough.
And the most important thing is , my custom etching is arrived !
It is not as good as i wanted. The little holding "ears" in the parts are molted , so the whole parts are falled out from the frame. They comes with plastic bag
But the details are good , just a few parts are damaged badly. It will be a real puzzle to figure out wich part is what.
Soon i started to solder them
Thanks for the commments !
Old 09-22-2009, 03:28 PM
mykman
Little teaser from the etching. :
The ammo case parts , and some suspension elements.
DML Sd.Kfz.234/3 Schwerer Panzerspähwagen (7.5cm) James Tainton Photos: In-progress Blogs 11 08-16-2007 11:41 PM
Schwerer Plattformwagen SSY. Uruk-Hai planetArmor General 3 05-14-2006 03:06 PM
