Go Back   planetArmor > planetArmor Features > Reference
Reference Share what you have
Old 12-14-2013, 08:34 PM
Kapitšn Dave's Avatar
Kapitšn Dave Kapitšn Dave is offline
Sherman II (M4A1) at El Alamein Oct. 1942
Hello Sherman aficionados,
I need help with my Dragon Models October 1942 El Alamein Sherman II (M4A1) 1/35 model build. My plan is to build this tank of "B" squadron 3rd Royal Tank Regiment. My questions:
(1) Was the demarcation between the camo colours hard (brush painted) or soft (sprayed)?
(2) Which type of the two grouser bin / gas tank vent covers on the upper hull at the back of the tank should I use? The choices are rounded or squared off covers.
(3) The engine deck has depressions at the far corners next to the engine access door corners. Dragon have parts to fill these if the modeler wishes to. Which, if any, should I use?
(4) Were three perpendicular straps across the back of the box attached to the rear of the turret usually used?
(5) should I add the lifting loops on the suspension bogies? And If so should they face up or down?
(6) Any other suggestions and points to make the model better would be much appreciated. Thanks for taking a look at this and for any help you can offer.
Best,
David
In Spurius noli te frangat.
1/35 Sherman M4A1 HVSS AK73 Photos: Finished Projects 4 08-18-2013 01:37 AM
My first vBench - M4A1 (76) W Sherman Robcio Photos: In-progress Blogs 62 12-15-2011 02:28 PM
Vol 17 SBS Sherman M4A1 76mm bladerunner8u Your important news and kit reviews. 2 01-04-2011 02:30 PM
Bishop 25 pdr SPG - El Alamein 1942 MEBOS Photos: In-progress Blogs 6 06-16-2010 02:36 PM
M4A1(76) Sherman Jakub Talib Jastrzębski Photos: In-progress Blogs 1 07-02-2006 03:48 AM
