Old 02-09-2008, 11:58 PM
WisdomED's Avatar
WisdomED WisdomED is offline
Marine Sherman questions
Greetings! 15 months and 2 purple hearts and its time to model. I am doing DML M4A2 wih the field mod trunks. The only picture picture I have is the common one of the 77th Marines cruzing down the trail. The only markings I can make out is the number 1 on the trunk housing. Does anyone know if it had any other markings? Or any other M4A2 with the field mod trunks? I want to ease into the swing of things and keep it pretty much OOB. I will be putting it in a simple dio like the mentioned picture above. With that said would it be appropriate to use a Ha Go wreck or a Te Ke wreck for a void filler. I think these field mod trunks were most common in Iwo Jima and Guam.
Any help would be appreciated.
Trust your hang,
Eric
Old 02-10-2008, 11:00 AM
panamadan's Avatar
panamadan panamadan is offline
panamadan
Glad to see that you made it back-I'll check my books. Dan
Old 02-10-2008, 12:57 PM
Eric
Which kit are you using? Academy? Are you using the kit decals? I have the Academy kit stalled on my bench and I have some pics of M4A2's with wading trunks. I'm not sure what are field mod trunks though.
Old 02-10-2008, 01:20 PM
WisdomED's Avatar
Lawrence-I am using the 1/35 Dragon M4A2 Tarawa kit with the 55 gallon oil drums for the wading trunks from Tank Workshop. The only picture I could find was in Allied-Axis #8 on pg 22. It would be perfect for my build, but I need more info or a profile shot of this tank or one like it. In the picture it looks like it is OD green and the only marking I can see is a beig number 1 on the trunk housing. I won't be using the kit decals if that is the case. I guess these 77th Marines where actual US Army M4A2s?
Eric
WisdomED's Avatar
Thanks Dan! Great to hear from you!
Old 02-11-2008, 10:15 AM
Eric
Only managed to find this photo in Ground Power which is in Allied Axis #8 as well. I will keep looking.
Old 02-11-2008, 11:17 AM
WisdomED's Avatar
That's a sweet picture Lawrence. I appreciate the help. With the drums they look like a mini Titanic.
Eric
Academy M4A2 Sherman U.S. Marines Questions ! dukwhunter Allied: World War II 8 06-03-2009 08:57 PM
New Marine Sherman from Dragon? halaci Your important news and kit reviews. 6 11-14-2007 06:07 PM
Marine T.C. figure firing .45??? Havoc Reference 2 12-19-2006 03:04 PM
Marine figure menardi planetArmor General 0 11-13-2005 09:17 PM
Sherman Questions..... TreadHead Allied: World War II 13 06-26-2004 07:44 AM
