Old 01-18-2012, 04:17 AM
Iron Horse Cossack - 1/9th vignette.
Iron Horse Cossack, 1/9th scale vignette.
In-Progress.
Users like alexwencho's post!
Old 01-18-2012, 04:44 AM
180 view.
The Following 3 Users Say Thank You to alexwencho For This Useful Post:
Old 01-18-2012, 03:49 PM
Did you scratch the weapon too?
Saúl García
Yesterday is History
Tomorrow is a Mystery
Today is a Gift
It is why it is called The Present!
Old 01-18-2012, 05:35 PM
1/9th PPSh-41 SMG (re-worked)
Thank you for asking and thank you for making me go thru my photo files to find these images from a couple of years ago when I began this build.
See what happens when you put me to work, take off my 'admin' hat and put on my scratch-builder hat.
Thank you and much appreciation for that.
Here is a good reference photo to aid with the 're-work'.
The Kit resin part 're-worked' with new gun barrel cooling shroud scratch-built from styrene plastic.
A photo the old resin part with the 're-worked' PPSh-41.
The trigger guard was fabricated from flatten aluminum tubing.
A&B epoxy putty shaped for breech block.
Flattened aluminum tubing shaped for charging handle and fire select toggle switch.
Bent wire shaped for gun strap loops.
Aluminum tubing for inner gun barrel.
Old 01-19-2012, 07:08 AM
cobblestones...
Sculpting, roughing-out cobblestones with two part epoxy putty.
Old 01-19-2012, 08:45 AM
alexthegreat! that look amazing! can't wait for more
Old 01-19-2012, 09:04 AM
Thanks for the reply on the gun... now to make you lose the Administrator hat as you find some photos for the bike since you didn't mention the brand! (unless it is Iron Horse which seems to me that you are referring to a Cossack not on a organic horse.)
Saúl García
Today is a Gift
Old 01-20-2012, 02:32 AM
Got Chain?
Sharkmouth, you are awesome. You are making me 'work' here on PA and I appreciate that.
Got Chain?
Old 01-20-2012, 03:57 AM
Got fenders?...got struts?
GOT FENDERS?...GOT STRUTS?
...well, I DO!...and there is some converting and scartch-building going on here with kit parts, styrene strip, miniature brass hardware and aluminum tubing.
"styrene, and aluminum, and brass, OH! MY!" "Toto, I've a feeling we're not in Kansas any more"
Old 01-20-2012, 07:02 AM
Dumo Dumo is offline
Pozdrawiam Rafal Sadurek
Very realistic
tank from WAR HORSE jtrowbridge5 The Great War 4 03-01-2014 02:55 AM
Horse cavalry - gun section Jendrass Photos: In-progress Blogs 9 09-04-2012 03:23 PM
Iron Horse Cossack, update: aug. 3,11 alexwencho Photos: OTA (Other Than Armor) 12 08-04-2011 02:40 AM
Hearts of Iron Coops Gamers Corner 1 02-25-2008 07:38 AM
What soldering iron to use? panzerjager planetArmor General 2 01-23-2008 10:12 PM
