Old 06-16-2006, 02:02 PM
Been using my new airbrush for a week now. (Double action gravity feed.) Yesterday when I tried to do fine mist it does that for about 2 seconds and then stops. When I pull back on the lever and it starts coming again but then there is too much paint. When I release the trigger and try again everything happens the same way. :angry:
I disassembled it and cleaned it through well and nothing seems to be broken. The needle seems to be straight and the nozzle ok.
Tried to do some painting today and the same problem appeared.
My compressor is a small one but it has a small airtank. I tried different pressures but the result is the same as mentioned above. I dont have a moisture trap as I have used the compressor since christmas with a single action external mix brush and everything has been OK till now.
My main guess is that because the weather is getting warmer here the air is more moist and because the new airbrush is more sensitive to moisture.
I really dont want to buy a moisture trap only to find out that the problem is still occouring. But if I really have to do that then I can't buy it untill monday when the hobby shop opens again.
And to top it all of all the painting has to be done by Tuesday evening for a competition.
So can please anyone help me with this problem? I am really desperate.
Best wishes
Siim
Old 06-16-2006, 03:56 PM
What kind of airbrush do you use, Siim?
It sounds like the paint isnt thinned properly or perhaps not well stirred? What kind of paint do you use, what do you thin it with and in what ratio?
Could also be the nozzle that isnt tightly fastened, especially if its an Evolution airbrush.
Old 06-16-2006, 05:05 PM
The airbrush I'm using is a Revell Master Plus IDG 950. It's adouble action brush with a gravity feed cup. But on the box it says in small lettering: ''This Vega model by Thayer & Chandler is exclusivley distributed by Revell AG'' so it is practicall the same as a Vega 1000. A lot of confusing information. :lol:
I use Model Master, Revell and Humbrol enamels. I thin them usually 50/50. I thin them with White Spirit. When the problem occoured then I tried thinning it down to 20% paint and 80% solvent. Still no change.
I believe the nozzle is thightly fastened.
The manual also says that the nozzle and spray head form a unit and when taken apart should be sealed again with wax. I haven't used any wax, should I?
Siim
Old 06-16-2006, 06:54 PM
mnickolson mnickolson is offline
Siim,
I use Model Master and Humbrol enamels but I use a enamel airbrush thinner not White Spirits. Not sure if spirits should be used like that in a airbrush, just mhop
Mike
"Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so."
Douglas Adams
Old 06-16-2006, 09:13 PM
Siim,
white spirits should not effect your airbrush, I run mine and clean with sprits and it's fine. If you have a moisture problem you would know as your brush would be spitting the moisture out through the nozzle creating water dots on your paint.
If you have cleaned the brush thoroughly, have enough pressure and nothing on the airbrush is bent or broken then it must be the paint mix. Double actions require a much more fluid mix than an external mix.
Hard to advise much else from here without actually using the brush.
Old 06-16-2006, 09:38 PM
Siim,
Ian has good advice for your setup. I even run laquer thru my Iwata and it is fine. As far as wax, that is to make the needle slide more easily through the rubber o-ring internally which seals the front where all the air and paint mixing take place. I would say from your description of the problem .... are you aware of how double action triggers work? I really don't know what else the problem would be.
Maybe your paint is old? or has hardened particles in it? you may need to strain the paint.
Old 06-16-2006, 10:20 PM
I guess I am learning something here also. Larry and Ian you thin your enamels with white sprits? Hmm I clean with it and use it with wash's but have never tried thinning my enamels with it. May have to give it a try.
Mike
Douglas Adams
Old 06-16-2006, 11:03 PM
Hi Mike,
Mineral spirits, white spirits, turpentine, paint thinner , I believe is all basically the same stuff. And the fancy names model paint companies give their products like airbrush thinner, brush cleaner, is the same as paint thinner or turp, etc.... then there is laquer thinner, for metallic paints, and clear coats. Hope that helps.
Old 06-17-2006, 12:51 PM
It seems to me on your description that the nozzle tip might be clogged. Have youve cleaned it properly? Try to clean it more an tighten every screw. Also check gadgets and O-rings.
Old 06-17-2006, 04:23 PM
Thanks guys for all the tips.
I will check every element of the brush first thing tomorrow.
Siim
Looking for an airbrush jorgeonline planetArmor General 4 06-06-2006 07:57 AM
Cleaning airbrush DOJO Painting & Weathering 12 01-29-2006 10:42 PM
