Old 11-12-2007, 04:19 PM
lupanzer's Avatar
lupanzer lupanzer is offline
Small Scale...big Project!step By Step(sbs)
Hi friends of this forum!
Iīll show you my "Das reich" Tiger I.in a SBS building form.Iīm using the 1/48 scale Tiger I fromTamiya,with Ediard P.E. and resin link by link tracks from WWII Productions (an Aussie company)...
The references are a must for every modeller and or enthusiast...
The version that I chose...
In the kit assembly,I observed a problem that must be corrected:"There is a gap in the whole turn between the upper deck and the cast metal hull"...Strips of plasticard were glued and sanded untill a perfect fit was achived.See the pics that show how I corrected this...
See you in the next!
Luiz.
Old 11-12-2007, 04:39 PM
lupanzer's Avatar
...letīs see now,an improvment that I did in the lower hull of my Tiger.Itīs the prominent welded flange reinforcing the joint between the lower hull side and sponsor floor".See the real one....
...and how I did this in my one...
Luiz.
Old 11-12-2007, 06:02 PM
Primus's Avatar
Primus Primus is offline
Another interesting start! Luiz where have you been hiding?
Old 11-12-2007, 06:39 PM
lupanzer's Avatar
Dear Primus... a timer and a good tripod work very well
Thanks! Luiz.
Old 11-12-2007, 06:58 PM
lupanzer's Avatar
...another lower hull improvment : I did some weld seams un the front corners...see the real one...
...see now the sequence,when I did the my ones...I used Green Putty and the tools showed...
Luiz.
Old 11-12-2007, 10:05 PM
Great work Luiz
Old 11-13-2007, 07:39 PM
lupanzer's Avatar
Thanks again...Fletcher!
Luiz.
Old 11-13-2007, 07:49 PM
lupanzer's Avatar
...the molded on tools in the Tamiyaīs Tiger arenīt a good representation,so,I decided to remove them and Iīll take advantage of them in a future building stage.
At first, note that in the real one,the tools are moved away from the top hull...
...and now, my method of removing the tools...really,itīs a risk task...
Luiz.
Old 11-13-2007, 08:34 PM
Rayman Rayman is offline
ouch that is some surgery you did. Great to see a 48th Tiger build, some excellent work here Luiz
On my Tiger I squished the side together and sanded the front of the sides down so the top could slide to the rear removing the gaps.
Did you see this build? http://www.robert-doepp.de/en/projec...iger/index.php
Robert re skinned the metal sides with thin plastic plate to make detailing the sides easier.
I will follow your build closely.
Ray
Old 11-13-2007, 09:13 PM
lupanzer's Avatar
Dear Ray...thanks for the interest!
The Robertīs work is fantastic!...Iīll be glad a lot if my Tiger will be similar like him...
Cheers!
luiz.
Small scale stuff Jan Peters Photos: In-progress Blogs 11 12-07-2007 10:41 AM
Small start for my next project Ebbe Bergman Photos: In-progress Blogs 4 12-06-2007 08:36 AM
PZ V Panther - really small kitty Czarny Photos: In-progress Blogs 8 06-16-2007 04:13 AM
251/1 D small scale Caranthir Photos: In-progress Blogs 14 06-08-2007 01:19 PM
Small Ferdinands Finnmodeler Photos: In-progress Blogs 4 08-10-2005 02:52 AM
